How to get all weldPoints from MfgLibrary?
How Can I get all weld Points of Mfg Library through API when some of them are TxWeldPoint in loaded status and others are TxPlanningMfgFeature in unloaded status?
Thanks in advance!
Re: How to get all weldPoints from MfgLibrary?
Hello @Joe0320
Assuming unloaded MFGs are not assigned to a weld operation, you can get them using Power Bar:
But for a better and precise result you'll need APIs, and actually because you're working with planning objects you may check eMServer API Manual (that's inside TX installation DVD). I don't have experience with this library, maybe someone else can give you better explanations on your need
