How to get currently active form/viewer?
is there any way to get the currently active form or viewer of Process Simulate?
then maybe I can get some attributes(controls value) of the form/viewer.
thanks.
3 REPLIES 3
Re: How to get currently active form/viewer?
Through TxViewersManager Class there is a GetActiveViewer Method.  Give it a whirl. Smiley Happy
TxViewerControl activeViewer = TxApplication.ViewersManager.GetActiveViewer();
and any way to get the active form?
What do you mean by form - maybe an example?  When I hear form I am thinking that it is a custom TxForm that is designed by you, so it should be pretty easy to deterimine whether it is active.  If this is what you mean, there is a Focused property for windows controls.
