How to get/set robot joint?
Hi everyone,
I tried to get and set a robots' joint values (6-axis Kuka) but didn't find a solution.
Probably an easy issue but I don't have any idea (and no experience).
So if anyone could help me please feel free to do :-)
Kind regards,
Jan
3 REPLIES 3
Re: How to get/set robot joint?
you can get an actual pose of a robot over CurrentPose property of the robot.
Alternatively you can access the joints over Joints property of the robot and then use CurrentValue property to get current rotation/translation position of the joint.
Witalij.
Hello Witalij,
thanks for your answer. Could you please explain it a little more detailed?
Maybe with a short code-snippet?
Thanks a lot!
Jan
Here is it:
 Private Sub RobotTest()
        Dim robot As TxRobot = TxApplication.ActiveSelection.GetItems()(0)
        'Get joint values over CurrentPose
        Dim poseData As TxPoseData = robot.CurrentPose
        For Each value As Double In poseData.JointValues
            'Do whatever you want
        Next
        'Iterate over joints
        Dim joints As TxObjectList(Of TxJoint) = robot.Joints
        For Each joint As TxJoint In joints
            'Read joint value
            Dim value As Double = joint.CurrentValue
            'Set value
            Dim newValue As Double = 255.0R
            joint.CurrentValue = newValue
        Next
    End Sub
