How to import JT file into PS?
Is there a way to import JT file into PS. Appreciate for any reply.
3 REPLIES 3
Re: How to import JT file into PS?
Thanks for your information
Direct way to import JT files in Process Simulate
You need to install appropriate CAD translator to carryout direct import
  • Create new study or use existing study
  • Go to file>> Import/Export
  • Convert and insert CAD files
  • In new window select add to browse JT files
  • New viewer with File Import setting appears
  • sysroot will be your target folder
  • Define Class types
  • Additionally, you can set the required options
  • Click ok and Import
  • Component import to status is displayed
Find the attached Images
Best Regards,
Jeethan Rohan
