How to move objects at a certain distance
After I got a object's TCP frame,how can I move the object from this  TCP frame to another frame?
5 REPLIES 5
Re: How to move objects at a certain distance
Anyone knows?
Just want to know is there any way to use the command“Relocate”.
Appreciate for any reply!
Hi Simona,
it doesn’t make sense to use relocated command...
But you can manipulate the objects location directly.
Each locatable object has a property .transformation as TxTransformation, which
consists of the TxVector’s .translation and .rotation
You simply need to calculate a new TxTransformation and assign it to your objects .transformation
If no simulation runs, refresh the 3D viewer afterwards.
Thanks for your reply.
But how to calculate a new TxTransformation which only changes translation and  maintains  rotation?
// Creating a new Transformation
TxVector _translation = new TxVector(100, 50, 200);
TxVector _rotation = new TxVector(0, 0, 0);
TxTransformation _offset = new TxTransformation(_translation, _rotation, TxTransformation.TxRotationType.RPY_XYZ);
This is how you can create a new TxTransformation which only changes the translation.
romox
Thanks a lot!
It did work.
Best Regards,
Remond
