How to run Import Object command from API?
Hello Experts,
I want to import MFGs to MFG library. Manually, I will right click on MFG library and use command "Import Objct" by giving input csv file which have details for MFGs.
Is this possible to import mfgs using APIs?
Re: How to run Import Object command from API?
Hello Ravi,
It is not possible to run that command from the API.
Best Regards,
DianaG
Hello Diana,
Thanks for the reply.
Betreff: How to run Import Object command from API?
TxWeldPointCreationData WeldPointCreationData = new TxWeldPointCreationData(WeldPointName, TransVector);
TxWeldLocationOperationCreationData WeldLocationOperationCreationData =
                       new TxWeldLocationOperationCreationData(WeldPointName, "AnyInfo", 1, WeldPointCreationData);
TxWeldLocationOperation WeldLocationOperation = WeldOperation.CreateWeldLocationOperation(WeldLocationOperationCreationData);
TxWeldPoint NewWeldPoint = WeldLocationOperation.WeldPoint;
Hi Ravi,
try this, maybe it will help you.
Hello Henry,
Thank you for your reply.
I will check it.
Ravi
Hi @DianaG
Can the interface IEmpImportCollection achieve the function of Import Object?
I have try the method 'ImportFromString' and 'ImportFromURL',but failed,which confused me for a long time.
Hope for any reply.
Best Regards,
Remond
FYI.
The functionality you are trying to create by your own is already available OOTB in PS Standalone eMS Based (csv Import) or in PSon eMS (csv/object import).
You only have to use the functionality and follow the rules.
Best regards
Patrick
Hi, Patrick,
I know the function. But are the points also connected to a part?
Henry
for csv import on eMS:
class,externalid,name,location,operatesOn (as far as I remember operatesOn is the parameter for your part, here you need to enter the external ID of the part)
for csv import in PSZ:
https://docs.plm.automation.siemens.com/tdoc/tecnomatix/14.1.2/tecnomatix_eMS/#uid:id1374671967772
Best regards
Patrick
