How to select subcomponent of PartPrototype
I have created a kinematic link through API and now i want to assign Link element to created link by selecting component. But whenever I select a component under PartPrototype, It was selected complete PartPrototypew instead of Subcomponent. How can I select a Subcomponent under Prototype. I have 3 Geometry under PartPrototype and I want to assign one of them through API. I want to select geometry from Graphics viewer, not from Object Tree.
1 REPLY 1
Re: How to select subcomponent of PartPrototype
Hi Luisy,
As I already added, you can use the TxPickListener to get picks from the Graphic Viewer. Another option is to change the PickLevel programatically and then to take the selection - Tecnomatix.Engineering.Ui.TxGraphicViewerConfig.PickLevel = TxPickLevel.Entity;
Best Regards,
DianaG
