How to update name of signals
I have created Starting Signals of NonSim operations exist in study. But when i change name of Non Sim Operation ,the respective start signal's name is not changed. It leads to a problem that user can not recognise which signal is for which operation.
How can i update name of Starting Signal, when its Non SIm operation's name change.?
Thanx
Re: How to update name of signals
the signals and its operation have a mapping? if have, you can get the signals' name and rename the signals.
maybe you can try TxRosePlc.PlcSignalGetResources(signal), it returns an array (ITxObject) if that is an operation, you are lucky.
