How to use TxLogWriter?
I cannot new the TxLogWriter, there's no a way that I can use the TxLogWriter.
Can anyone give an example?
thanks.
4 REPLIES 4
Re: How to use TxLogWriter?
Siemens Legend Siemens Legend
Siemens Legend
the TXAPlication holds a static members- LogWriter that can return an instance of TxLogWriter.
TxApplication.LogWriter.WriteInfoLine("my Info!");
Hi, @Ofer
Thanks for your reply, now I know how to get an instance of TxLogWrite or I can use the static method to write the message.
and I wanna know where the log file then I can delete it or backup it for different commands.
thanks.
Siemens Legend
The log settings (level & location) are set in the "empower doctor" menu, under Tools\Tecnomatix Application Log.
Hi, Ofer
thanks. maybe the interface can be exposed?
