I would like to create plane by API but got an error message
Siemens Legend Siemens Legend
Siemens Legend
Question:
They would like to create plane in modeling by API.
 I try to create plane by API but I got Error message.
I tried to some patterns(see attached file) for creating plane,
but cannot create plane.
Could you please tell me way of thinking of edgeList.
Sample:
            TxLocalComponentCreationData data =
                new TxLocalComponentCreationData("test");
            TxComponent newComp =
                physRoot.CreateLocalComponent(data);
            ITxGeometryCreation geoCreation = newComp as ITxGeometryCreation;
            ITxLocatableObject locObj = newComp as ITxLocatableObject;
            ArrayList edgeList = new ArrayList();
            edgeList.Add(new TxVector(0,0,0));
            edgeList.Add(new TxVector(1000,0,0));
            edgeList.Add(new TxVector(0,1000, 0));
            TxPlaneCreationData planeData =
                new TxPlaneCreationData("testPlane",locObj.AbsoluteLocation,
                    new TxVector(0.0, 0.0, 1.0),edgeList );
            try
                TxSurface surObj = geoCreation.CreatePlane(planeData);
            catch (Exception e)
                TxApplication.StatusBarMessage = e.Message;
Answer:
CreatePlane method throws TxNotImplementedException  when this function is called in Process Simulate or Process Designer.
So the customer cannot create a plane object under component.
They can use the manipulator object  TxManipulator and create a plane under it with TxManipulatorPlaneElementData.
Example:
TxManipulatorCreationData crData = new TxManipulatorCreationData(“TestManipulator”, new TxTransformation());
TxManipulator m_planeManipulator  = TxApplication.ActiveDocument.PhysicalRoot.CreateManipulator(crData); TxManipulatorPlaneElementData manipElement = new TxManipulatorPlaneElementData(new TxTransformation(), width, height);m_planeManipulator.AddElement(manipElement);
