Is there a way to use commands already given by Process Simulate?
Siemens Legend Siemens Legend
Siemens Legend
Question:
Is there a way to use commands already given by Process Simulate? Execute them using a "name of the command" as a parameter? I've seen this somewhere in the API docs but i can't find them anymore.
Answer:
 Commands can be executed with CommandsManager:
TxApplication.CommandsManager.ExecuteCommand("EMServer.Properties");
TxApplication.CommandsManager.ExecuteCommand("ObjectViewing.Blank",
       new TxMultipleObjectParameters(TxApplication.ActiveSelection.GetItems()));
We recommend to use this utility for custom commands(commands that you have created) as some changes may be introduced to PS commands in future versions.
More over most of the functionality is covered by the .NET API and users may implement their own logic.
Here is the list of commands, that we provide in the API manual that can be used with CommandsManager:
EMServer.Properties
TxPropertiesViewerParameters
Shows the Properties of an object.
EMServer.Load
TxEmsOpenStudyParameters
Loads an object to the graphic viewer.
ObjectViewing.Blank
Blanks objects.
ObjectViewing.Display
Displays objects.
ObjectViewing.DisplayAll
None
Displays all objects.
SnapshotEditor.AddSnapshot
TxSingleObjectParameters
Creates a snapshot.
The snapshot is returned as a parameter.
SnapshotEditor.RemoveSnapshot
Deletes a snapshot.
SnapshotEditor.UpdateSnapshot
Updates a snapshot.
SnapshotEditor.ApplySnapshot
Loads a snapshot.
