LineSimulationMode Difficulties
Hello All,
I got all the list of Parts (Txcomponent) through this below given code in standard mode. and then i made dropdowlist for Parts. I want to get that list also in Line Simulation Mode. But as TxComponent is changed to TxPartAppearance , i can not get list of partappearance in dropdownmenu. Is there any method available through which i can get dropdownlist?
public TxObjectList GetListOfParts()
            TxObjectList components = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxComponent)));
            TxObjectList planningComponents = components.PlanningRepresentations;
            TxTypeFilter partsFilter = new TxTypeFilter(typeof(TxPlanningPart));
            TxObjectList planningParts = partsFilter.Filter(planningComponents);
            TxObjectList engineeringParts = planningParts.EngineeringRepresentations;
            return engineeringParts;
Re: LineSimulationMode Difficulties
Siemens Legend Siemens Legend
Siemens Legend
once there are appearances, you ca nuse this one:
(VB example)
m_AppFilter As New TxTypeFilter(GetType(ITxPartAppearance))
TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(m_AppFilter)
Moshe
HI @Hazan,
Thanx,
But i need to get list without generating appearance from operatons. Do u have any idea?
