Load library Implementation error
I have added all the required libraries(from empower) and controls(from empower32) correctly. All other controls are worked perctly. Only when I have added Tx3DVectorCtrl and tried to save it, it throws exception,
Exception: Could not load file or assembly Implementation, version=14.1.2, Culture =neutral, PublickeyToken=Null or its dependencies.
I am using 64 bit version of Tecnomatix and have alkready added Implementation library. What could be the reason behind not loading library?
6 REPLIES 6
Betreff: Load library Implementation error
What platform have you chosen in the configuration manager? Try it with another setting than x64.
@MarkusH
I have tried with AnyCPU but still it does not work. For more clearity, I have attached Pic. Any other suggestion?
@Bishen @ @MarkusH ,
I have same kind of roblem with controls few days ago. I just ignore that exception and run it. It works fine. I didnt chnage any configuration settings because other controls already worked fine. Try just ignore that exception and run.
@ChristyBell ,
It works. Thanx
Siemens Legend Siemens Legend
Siemens Legend
why do you reference the implementation.dll? you are not suppose to.
@OferOhayon ,
usually it referenced over Tecnomatix.Engineering.dll and designer in VS tries to load it.
