OperationLink between two WeldOperation
I want to link two WeldOperation from different CompoundOperations. Is there a Trick to do this? The direkt way does not work!
Thanks in advance, Steffi
Re: OperationLink between two WeldOperation
Siemens Legend Siemens Legend
Siemens Legend
You can only link them if they are under the same compound operation. You can move them under the same compound op and then link them.
Okay, thanks.
