[PS] Accessing kinematic informations of a jt-file
ist it possible to access the kinematic informations (links, joints, joint limits) of jt files with API?
Re: [PS] Accessing kinematic informations of a jt-file
Hello, Markus,
The API works with the loaded objects (devices), not directly with the jt.
Best Regards,
DianaG
Betreff: [PS] Accessing kinematic informations of a jt-file
Hi, Markus!
You can load the JT file to PS, creating the cojt if needed in the way described in How to create a .cojt with TuneData.xml from the API and than access the kinematic data.
A-S-E
