Problem creating viewer
Hello experts,
Create new viewer with example , registered using ViewerReg.exe and put the newly created dll under <installation  Dir> DotNetExternalApplications folder. But not able to see the new viewer under viewer menu.
Any idea what I am missing ?
Sandeep
7 REPLIES 7
Re: Problem creating viewer
Hi, @sandeepmore
if your viewer is created with the example, I think the viewer will be on the Viewers menu.
Betreff: Problem creating viewer
your workflow is completely wrong.
1. Move your .dll to DotNetViewers-Folder instead of DotNetExternalApplications-Folder
2. Call ViewerReg.exe
3. Start Process Simulate
Hi Mark,
I follow above steps still I don't see viewer under viewers menu.
Not sure what I am missing ?
Sandeep
Siemens Legend Siemens Legend
Siemens Legend
When you run the ViewerReg, have you seen your new viewer in the list? Did it created the xml file?
Hi Beterff,
Yes it is. But after registering it and opening process simulate to see the viewers menus it is not showing in that list. Does it process simulate has any logging system or how to debug this case to see what is wrong ?
Sandeepp
I would suggest that you post your code here
And also some pictures of your DotNetViewer and DotNetExternalApplicationFolder!
Finally able to load custom viewer. The mistake I was doing not created a user control, I was using a form.
Sandeep
