Problem with VS2010 PS 13.0 Tecnomatix.Engineering.UI Controls
i´m looking for some support on using the UI Controls.
The Problem is that i can´t implement the UI Controls as described in the helpfile.
I always get an error like in the attached picture.
I´m using:
Windows 7 64bit
PS 13.0
VS 2010
I tried on exisitng project and also on complete, clean new projects: always the same error.
Referencing the dll is working, but i don´t get access to the Controls in the Toolbox.
Need an idea where to look for the fault...
Greets Fred
Re: Problem with VS2010 PS 13.0 Tecnomatix.Engineering.UI Controls
Hi masterSim,
You can check in this video. You need to add the controls to the Toolbox using Tecnomatix.Engineering.UI.dll from eMPower32 folder.
Best Regards,
DianaG
