Process Simulate on Teamcenter , item icons based on property value
I have a single item defined in teamcenter that has an property renderer attached wich changes my icon depeding on it's value.In teamcenter i have a3_item with a3_role property wich can take gripper ,conveyer etc values (based on a list of values) . When i change the property value to gripper the gripper icon is displayed .
When i am loading the a3_item in process simulate , the default icon for a3_item is displayed , totally ignoring my property value .
Does anyone have an ideea how i can make Process Simulate show specific icon for same item type based on a property wich is exported from Teamcenter?
Thank you .
Re: Process Simulate on Teamcenter , item icons based on property value
Hi lonutBilibou,
There isn't a way to configure object icon based on property value.
The object icons in Process Simulate are based only on the object type.
Best Regards,
DianaG
Hello Diana,
Thank you for your answer.
Best regads,
Ionut Bilibou.
