Read and modify OLP commands
Good morning
I am trying to create program that reads OLP commands from selected locations and copy it to others selected location. First I was trying to collect data and show it as string in text box.
private void mOLP_Picked(object sender, TxObjEditBoxCtrl_PickedEventArgs args)
ITxRoboticLocationOperation locOp = args.Object as ITxRoboticLocationOperation;
if (locOp != null )
TxObjectList ComList = locOp.Commands;
for (int i = 0; i < ComList.Count; i++)
{mOut.Text += ComList[i].ToString();}
My list contains only one element and this solution returns only "Tecnomatix.Engineering.TxRoboticCommand" text which is not a command name, how can I get access directly to OLP commands?
