cancel
Robot program pointer API
Hi
Is there any way to get a robot current program pointer like the Simulation monitor veiwer does while the simulaiton is in play mode with the API. Things like what operation/location the robot is currently executing?
Re: Robot program pointer API
i didn't found out something like this.
But if you add all related Operations to the Patheditor, you can see the actual driven Point, which is shown in fat font style
Hi
Thanks but I need to add some code while the robot is moving and not just visually see which point the robot is on
Did you already found a way to get the information via API?
I'm now in the same problem.
But i found the TxRobotSimulationEngineServicesProvider where you can find the RegisterToLocationReacheedNotification.
The TxRobotSimulationEngine provides method GetSimulationServicesProvider which gives the provider for TxRobotSimulationEngineServiceProvider.
Sadly, i don't know how to handle this abstract class.
Siemens Legend Siemens Legend
Siemens Legend
To get the currently simulated operation try registering to TxSimulationPlayer events like OperationStartedForward and OperationEndedForward.
Hi
Thanks Diana but I think what everybody is wanting is the current operation and location per robot and not the general current operation. Surely with the new simulation monitor this should be available as this shows this and a lot more. Is it because this is not exposed to the API?
