Robot velocity
Is there anything in the API that can achieve the same as the OLP command VelSet? i.e. setting a robot to a % velocity to have it run at that speed variably during a running simulation.
If yes, could someone please provide an example?
Re: Robot velocity
Hi LTW,
There is no API to influence the controller simulation during the simulation.
Best Regards,
DianaG
Re: Robot velocity
OK thanks.
