Select Component Programatically In Tree?
Is there a was to programmatically select a component from the object tree (ver 13.1)?   In other words, simulate picking it with the mouse so that it is highlighted and active selection?
Something like SelectNodeByInternalId(string InternalId)
Re: Select Component Programatically In Tree?
Have you tried to add the object of interest to TxApplication.ActiveSelection?
Ugh .. so simple!  Smiley Happy  I did not even realize that was an option, the only thing I ever use that for is to get user selection.  Thanks!
//ITxObject obj definded previously
TxObjectList list = new TxObjectList(); list.Add(obj);
TxApplication.ActiveSelection.Clear(); // Optional - depending on what you want to do TxApplication.ActiveSelection.SetItems(list);
