TxDockableViewerWindow for undocking GraphicViewer
Hello everybody,
i was trying to get the Graphic Viewer Window in floating mode by using the TxDockableViewerWindow class but it does´nt worked. I tried it also @object Tree and it worked well. Are they different implemented? How can I undock the Graphic Viewer? Attached you can find the examples for the Graphic Viewer an the Object Tree.
Thanks in advance,
Matte
4 REPLIES 4
Re: TxDockableViewerWindow for undocking GraphicViewer
Siemens Legend Siemens Legend
Siemens Legend
Can you share your code?
Sure...
TxGraphicViewer Viewer = TxApplication.ViewersManager.CreateNewGraphicViewer();
TxViewersManager ManageViewer = TxApplication.ViewersManager;
TxDockableViewerWindow Viewerdocked = Viewer.ContainerWindow as TxDockableViewerWindow;
Viewerdocked.Float();
Hi Matte,
Right, for now, controlling the floating state of the TxGraphicViewer is not supported.
Best Regards,
DianaG
Hi DianaG,
thank you for your reply. Then I will try to reach my goal by another way.
Greets,
Matte
