TxErrorWindow - How does it work?
How does the TxErrorWindow work?
The Class TxErrorWindow (Namespace: Tecnomatix.Engineering.Utilities) has two different subs.
(1) Show ==> This Sub works fine.
(2) ShowDialog ==> This Sub want to have the errors and warnings as Hashtable.
How could i build this Hashtable if i have a List(Of Exceptions)???
Thanks.
Re: TxErrorWindow - How does it work?
Hi EDAG-PS,
The Hashtables contain a string that defines the error/warning message and an array of strings that defines the suberrors/subwarnings.
Here is an example:
private void ShowErrorWindow(TxObjectList failedObjects)
       Hashtable errorsTable = new Hashtable();
       List<string> failedObjectsNames = new List<string>();
       foreach (ITxObject obj in failedObjects)
           failedObjectsNames.Add(obj.Name);
       errorsTable.Add("The following objects failed to ...", failedObjectsNames.ToArray());
       TxErrorWindow.ShowDialog("My Command", "The command encountered some problems during ...", errorsTable,
new Hashtable(), true); }
Best Regards,
DianaG
