TxManipulator visibility
I have tried to create Manipulator Gismo using following code. But it was not visible. Where is the problem?
 TxManipulatorCreationData creationData = new TxManipulatorCreationData("Name", baselocation.AbsoluteLocation );
                TxManipulator manipulator = TxApplication.ActiveDocument.PhysicalRoot.CreateManipulator(creationData);
Capture.PNGManipulator
Re: TxManipulator visibility
Hi @Luisy ,
U need to color Manipulator. Try with this
TxManipulatorCreationData creationData = new TxManipulatorCreationData("name", new TxTransformation());
               TxManipulatorLineElementData lineDataZ = new TxManipulatorLineElementData(new TxTransformation(), startpoint, endpoint);
 lineDataZ.Color = TxColor.TxColorLightBlue;
manipulator.AddElement(lineDataZ);
You need to call TxApplication.RefreshDisplay(); to update the graphics.
You may also need to zoom if your manipulator is too small. If this is the problem you can use the Unzoomable property of the TxManipulatorLineElementData to make it keep the same size when zooming in/out.
Best Regards,
DianaG
