TxSimulationPlayer: Play operation step by step
Hey there,
so I'm selecting a Operation with several Locations. I'd like to move to each to the locations step by step, instead of TxSimulationPlayer.Play(). With Play() I'm able to play the whole simulation at once, but I'd like to do something at each location.
 TxGenericRoboticOperation _genericOperation = _calibrationOperation as TxGenericRoboticOperation;
            TxSimulationPlayer _player = new TxSimulationPlayer();
            _player.SetOperation(_genericOperation);
            TxApplication.ViewersManager.PathEditorViewer.AddOperation(_genericOperation);
            TxObjectList _locations = _genericOperation.GetAllDescendants(new TxTypeFilter(typeof(ITxRoboticLocationOperation)));
            foreach (ITxRoboticLocationOperation op in _locations)
                TxRoboticViaLocationOperation _op = op as TxRoboticViaLocationOperation;
                //Here I'd like to just play until next TxRoboticViaLocationOperation is reached.
_player.Play() }
Am I missing any method?
Re: TxSimulationPlayer: Play operation step by step
This is an OOTB function in Path Editor when your specific operation is loaded.
Best regards
Patrick
At first thanks for your reply.
I already know the function inside the path editor.
I'd like to call this function with C# code.
To do this you can use the CommandExecutor.
TxApplication.CommandsManager.ExecuteCommand("Operations.PlayForwardToOperationStart");
I´m not 100% sure "Operations.PlayForwardToOperationStart" is the correct command but let have a try.
Best regards
Patrick
Hello Patrick,
thanks for your help. This kinda worked for me. I only need to find the correct parameter needed for the command.
I managed to find some information about ExecuteCommand:
It is possible that commandIDs (like "Operations.PlayForwardToOperationStart") change with new TX versions.
All commandIDs can be found inside the NewAssembler.xml under the eMPower folder.
