Unable to debug command
Unable to debug .NET application. I have only on Tune.exe running and attaching .NET application to attach to process Tune.exe. Saying no symbols loaded. Where do we need to put the command dll ? does PS looks at certain path that's why not loading newly created library ? Appricate your help
7 REPLIES 7
Re: Unable to debug command
hi,
you have to register a command for PS and than put it in the ribbon or quick start bar in order to get you library loaded.
There is a video how to create a command.
Witalij.
Or have a look in the Tecnomatix.Net.chm in your installation folder - e.g. C:\Program Files\Tecnomatix_13.0\eMPower\TecnomatixSDKHelp\
There you find the Creating Commands section.
I did register command and seeing the command in ribbon. But while attaching visual studio to Tune.exe, my class libray debug points are showing message libray not loaded. Don't know why getting this error ? Does the new libray dll put in any specific location ?
Hi
have a look at this discussion
You will find solution how to connect VS with PS, attaching to process or starting PS with debugger directly from VS.
Have a look at the last post. The information about Tecnomatix Doctor settings (disable  "Enable dump file creation" and "Enable diagnostic tool") is very important.
Best regards
Patrick
Finally it got worked
Sandeep More
what did you do to get it to work?
Please share your experience to the other community members!
I follow the same steps found in eariler posts to add Tune.exe in debug settings. While attach to proecss I cilck on browe buttion and click on the Automatic detemine debug radio button option and it works. Attached are snaps for reference.
Hope you will also found this helpful for others too !
Sandeep
