Using of the Attributes of ITxObject
can please somebody provide me further information about the attributes, that are accessible via the Attributes property of ITxObject interface.
What is purpose of this attributes, where they are supposed to use for, where they are stored…
The information in the API reference is a little too small.
Thanks in advance
Witalij
Re: Using of the Attributes of ITxObject
Hello  Witalij,
The attributes are mechanism to save simple data types (double, int, TxTransformation, string) to a model object instance. Data is persisted in the study data per instance (not per prototype).
Best Regards,
DianaG
Hello, Diana!
Thank you.
Is there any limitations to the string values of the attributes?
Hello Witalij,
Regular string type, saved as inner text of xml tag.
Best Regards,
DianaG
