Which is correct way to get all Geometry data from Cell ?
I am seeing below 2 ways to get all geometry data from a cell :
1. With TxComponent.SetModelingScope() as below :
         if(TxComponent.IsOpenForModeling)
2. or With libraryStorageObject as below :
          ITxStorable storableObj = documentObject.objValue as ITxStorable;
         TxLibraryStorage libraryStorageObject = storableObj.StorageObject as TxLibraryStorage;
         if ((libraryStorageObject != null) && libraryStorageObject.HasDetailedRepresentation)
                if ((txObject as ITxComponent).RepresentationType == TxRepresentationType.United)
                      libraryStorageObject.Reload(TxRepresentationLevel.Detailed);
Re: Which is correct way to get all Geometry data from Cell ?
Siemens Legend Siemens Legend
Siemens Legend
the first methods opens the component for modeling (and as a side effects loads its entities as well),
and the 2nd loads the entities.
