Zoom to a desired object
Hello!
Is it possible to zoom graphic viewer to desired  ITxDisplayableObject with API or should I use the command?
And one more general question: How can I control zoom of the graphic view in PS?
Best regards
Witalij
Re: Zoom to a desired object
you can use a Command for example:
TxApplication.CommandsManager.ExecuteCommand("GraphicViewer.ViewCenter")
or
TxApplication.CommandsManager.ExecuteCommand("GraphicViewer.ZoomToFit") //not sure if this command works
Thank you. I will try it.
You can also try:
TxApplication.CommandsManager.ExecuteCommand("GraphicViewer.ZoomToSelection")
