change location of a solid body from one point to another point
I want to move solid body from its absolute location to another selected point. I tried to use Translate method. But body changes its location not correctly. How can I do that?
component.Translate(new3dvectorpoint- absolutelocation.translation)
4 REPLIES 4
Re: change location of a solid body from one point to another point
Luisy,
have you tried
component.Translate(new3dvectorpoint)
Witalij
@Witalij ,
I tried Translate method but, I am confused to use it. For example, two vectors I have component.Absolutelocation.Translation =P=(x0,y0,z0), and Q=(x1,y1,z1). I want to move vector P to position Q. What parameter should  I give in Translate method?
@Luisy ,
I would try to use Q vector as parameter.
The exact description of the methos from API reference:
"This method changes the object transformation, by applying the translation vector to the translation represented by the matrix. This method does not change the rotation and mirror information."
Siemens Legend Siemens Legend
Siemens Legend
The API has a limitation where you can't set a property of a property. You'll need to use the AbsoulteLocation property with the new value.
Component.AbsoulteLocation=new Txtransformation(...)
