classification of operation
Hello all,
There are 10 Operations in Operation tree and 2 robots in production cell. In those Operation first 3 operations are executed by first robot, then next 4 operations are executed by second robot and last 3 operations again executed by first operation.
Can we classify each operation according to the robot responsible for exection of that operation?
Re: classification of operation
Hello @Vaghniku
Yes, you can classify. If your operation object implements ITxRoboticOrderedCompoundOperation, you can access the Robot property for that operation and classify it.
Hi, @FredCastro,
Thanx for ur valuable reply. But i could not understand exactly whats your code returns.
Can you explain somewhat in brief?
Thanx
