difference of RobotExternalAxesData and RobotDepartureExternalAxesData?
I try to get the robot external axes joint value, there are two properties like this:
TxRobotExternalAxisData[] exterAxis = ITxRoboticLocationOperation.RobotExternalAxesData;
TxRobotExternalAxisData[] exterDepAxis = ITxRoboticLocationOperation.RobotDepartureExternalAxesData;
I want to know that the difference between the RobotExternalAxesData and RobotDepartureExternalAxesData?
thanks
1 REPLY 1
Re: difference of RobotExternalAxesData and RobotDepartureExternalAxesData?
Siemens Legend Siemens Legend
Siemens Legend
The Set External Axes Values command enables you to configure and store the:
1. approach values of external axes for robot joints (rails, Servo Guns, etc.) - RobotExternalAxesData.
2. For Servo Guns, you can also configure the depart values -RobotDepartureExternalAxesData
