how to get info from application status bar when a ITxRoboticLocationOperation is set current.
Hi, dear all
how can I get info from application status bar when an  ITxRoboticLocationOperation is set current operation. I want to retrive the whole info constantly when the robot is moving from one loc to another.
Re: how to get info from application status bar when a ITxRoboticLocationOperation is set current.
Hi KongCQ,
I would suggest to use the events fired by the TxSimulationPlayer class rather than the text of the StatusBar.
Documentation:
At any given moment there is a single, current simulation player, with which all simulation-related commands and viewers work. To get the current simulation player, use the TxApplication.ActiveDocument.SimulationPlayer property.
Event examples:
OperationStartedForward
Started
Ended
For further events please check the documentation.
Andreas
