how to select objects outside TxObjGridCtrl box
I have added TxObjGridCtrl box and added few objects in it thorugh programming (not by pick object). Box is having read only properties. When i select any object in the box, then i can not select any object outside that box, so it behaves like semi model property, whereas it has no semi model property.
How can i enable selection from outside TxobjGridCtrl box?
Re: how to select objects outside TxObjGridCtrl box
@Vaghniku
Have you set ListenToPick property of your grid object to True?
