Assembly process planning of low-volume assembly operations using SAPPHIRE
Dr. Gert Nomden (@nomden) from Cards PLM Solutions talked about SAPPHIRE at the 2014 Plant Simulation Worldwide User Conference.  SAPPHIRE is a Plant Simulation object library available from Cards PLM Solutions. SAPPHIRE helps in creating a simulation model for low-volume assembly operations. Assembly processes that require managing complex assembly sequencing, time parameters and constraints are best solved by SAPPHIRE. SAPPHIRE is fully embedded in the Plant Simulation modeling environment.
Watch this video to learn more.
(view in My Videos)
Contributors
