Automotive BIW Concept Example Model - Tecnomatix Plant Simulation
Community Manager
This model shows how to optimize buffer capacities and how to compare similar models with different parameters.
Attachments include the Plant Simulation model file (.spp) and description (.pdf).
Mike Rouman
Senior Marketing Manager
Siemens Digital Industries Software Inc.
Comments
 Hello MikeRouman
I am new to Plant simulation and i am current using version 10.5 soo I wonder if it's possible to save Auto_BIW_Concept in Version 10.5?
Br Jfinnberg
Community Manager
I will ask our product team to save this model in 10.5, if possible. If so, I will have it added here. In the meantime, you can also download the free trial version to load and run this model - http://www.plm.automation.siemens.com/en_us/products/tecnomatix/free-trial/plant-simulation.shtml
Community Manager
@Jfinnberg, as you can see here, I have posted a Version 10 model for your use. However, I believe that you may have access to the latest release via your employer... I will send you a direct email, in that regard. In the meantime, if you use the V10 model posted here, please be advised that it may not work exactly as describe in the V11 documents and model.
Contributors
