Get external connected objects of Plant Simulation and write them into a table
Question
In Plant Simulation, is there a way to get all the external connected objects of Interface and write them into a table?
Answer
To get all connected objects of an interface in a table, you can use the following sequence:
for local i := 1 to Interface.numPred loop
predObj := Interface.pred(i);
tablefile[1, I ] := predObj;
next;
Contributors
