In Plant Sim visualize content of a subframe in the main frame
Question
In the 3D environment is it possible to see the contents of a subframe in the main frame ? Similar with the Representation option for the 2D environment...
Answer
In the "Edit 3D properties" menu (right click on object) you can activate "visible content"
Contributors
