Open with Line balancing Chart view
Question
In Teamcenter Manufacturing 9.1.2, I want to open the below Process Line of a plant BOP in line balancing chart view.
If I select ProcessLine, and Open Line Balancing Chart view using right click then it gives me message as "There is no station found under the current scope"
If I modify my structure as shown below then it works. I have to add all stations under Plant BOP
What is the trick to load a structure in Line  Balancing Chart view?
Answer
Set value of the preference MEAllocationLevel as Mfg0MEProcStatn.
