ABB IRC6 teach pendant supported?
Do you know when will the siemens teach pendant for ABB IRC6 be available? or if it is already supported in a current version.
Betreff: ABB IRC6 teach pendant supported?
hello,
what do you mean?
The IRC 5 (RobotWare 6) robot has the same syntax as the RobotWare 5 robots.
only the RCS Modul is new.
Kind regards,
Benjamin Voelzke
