ABB RCS problem for OLP
HI i have set up rcs and lic step by step as manual, but at last ,it appears as the picture shows, who can tell me what's wrong? thanks you very much!
Re: ABB RCS problem for OLP
check rcsaddr.txt in the RCS client folder. It should contain the IP of the RCS server.
also. please make sure your license for ABB RCS is being driven before you run this function.
i have tried the IP, but still doesn't work (before, it is computer name)
how to check if the license is being driven?
you can open RCS console which is a DOS windows to show the progress while you loading RCS functions. Normally if license doesn't work. it will return one issue in console. As well as the client-server connection for ABB RCS. Are you using Windows 7 and withould LAN setting up ( just using wireless)? it might be a issue here.  Server-client connection maybe fail and return one error code :10061...
thank you very much for your suggestion.
 i am use win7  (not wifi).
and where i can find the RCS console?
simply new try. connecting your computer ( laptop) to a local network and set the IP for your computer. try ping RCS server. if it works. it will be ok.
