Any option equivalent to Arc continues positioning(Robot Expert) in PS
Hello all,
Was using Robot expert and came to know about an option called  "Arc continues positioning" which helps robot to set external axis values of positioner to each location automatically.
Do we have any such option in Process Simulate similar to this where we can set external axis values of positioner automatically to a operation..? (am using process simulate 12.1)
Re: Any option equivalent to Arc continues positioning(Robot Expert) in PS
This command is included in OlpTool package that is available on GTAC
Thanks for your fast reply.
Is this specific to any particular robot model like fanuc, think had tried this option with a Yasakawa robot.
Have installed OLP for Fanuc and that option is not available.
It is independant from the robot brand
It is included in OlpTool, not in a controller package.
Is it possible for you to provide any snapshot for the location in GTAC since am searching around without idea.
Have go the location for OLP tool, will check and let you know. Thank you.
Its working fine now. Thank you. Was able to use the option.
