Associated objects are missing
Hi guys,
im using process simulate/designer 10.1 with standalone configuration.
In my current study I get problems while I try to load it:
Warnings:
One or more objects associated with the operations are missing:
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of Home1.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p20.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p30.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p40.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p50.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms35.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p52.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p56.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p60.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p70.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p80.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p90.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p100.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p110.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p120.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms45.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p130.
id = {0A11758E-8E0A-4CF2-9CFC-7518866516D0}, referenced by a robotic simulation parameter of ms15p140.
I´ve identified the robot which belongs to the program, but i can`t solve the error message. I`ve tried to reloaded the programm module, killed it, etc. But every time I load the study, I get the error message above.
Do you a solution for this prolem?
