(C# API) - Traverse Object Tree
I'm quite new in PS/PD. The current TxSelection class goves me access to the selected object,
but what if I want to retrieve all - lets say Weldoperations - under an Object. Is there a Function to traverse the children? I found some functions in theTxDocument namespace, but they did not work, i.e. I could not retrieve the desired object instead of iterating over the complete Documentcollection of the TxApplication.
also, how is it possible to load a PlanningObject ? I found some Shortcuts but no method to load the referenced object. How would one do that ?
Any help is appreciated
Re: (C# API) - Traverse Object Tree
to find a special type you can use type filters.
The following line allows you to get all frames from the object tree:
TxObjectList allDescendants = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxFrame)));
To get all Mfgs you only need to change from PhysicalRoot to MfgRoot
thanks for your reply. This seems logical so far, unfortunately whatever object I query I get an empty list as result. Same for MfgRoot. When I check the total number of documents (TxApplication.DocumentCollection) in my simulation I get a count of > 2Billion documents. I assume my current document is simply wrong/empty. How can I check which document is the current one ?
if you take "TxObjectList allDescendants = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxFrame)));" you need to have some frames in your ObjectTree, otherwise "allDescendants" returns "null".
Use "TxApplication.ActiveDocument"...
I searched for other type of Objects like TxPlanningObject or ITXObject. The only match was
when i used the filter for ITXObject. I think the problem is in my testdata, your provided code should work fine. thanks for your help.
