C# API: read out a color of an object
Does anybody know how you can read out a color from an Object?
I am able to set a color, but if I read out, I get an exception.
Excample:
TxObjectList objects = TxApplication.ActiveDocument.PhysicalRoot.GetAllDescendants(new TxTypeFilter(typeof(TxRobot)));
var color = ((TxRobot)objects[0]).Color.Color.Name;  //Doesn't work
Re: C# API: read out a color of an object
Indeed, it does not seem to work...
many people check this function in process simulate.
all people see the error of the API code in process simulate.
(API doesn't safe the color of object)
can you fix the problem or create a PR for this?
thanks
Kind regards,
Benjamin Voelzke
It is better if you contact Siemens hotline so that they open a PR to Core R&D.
