Calculating in Simulation-Layers
Hey guys,
is it possible to calculate with integers in simulation layers?
For example something like that:
<Line>
<Item Type="const"># WaitTime </Item>
<Item Type="parameter">Fraes_Impuls/3</Item>
</Line>
The solution above does not work. Smiley Wink Is this somehow possible or am I spoiled by other programming languages?
Re: Calculating in Simulation-Layers
<Line>
<Item Type="const"># SetVariable MyDelay</Item>
<Item Type="parameter">Fraes_Impuls</Item>
<Item Type="const"> / 3</Item> </Line>
<Line>
<Item Type="const"># WaitTime MyDelay</Item>
</Line>
should work
Hmm, there are still problems:
The code looks like this:
<SimulationLayer>
   <If>
      <![CDATA[('Fraes_Impuls'>=0)]]>
      <Line>
         <Item Type="const">/ 3</Item>
      </Line>
      <Line>
         <Item Type="const"># WaitTime</Item>
         <Item Type="const">MyDelay</Item>
      </Line>
   </If>
</SimulationLayer>
I get the following error:
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] OnLocationReached: 3,26591992378234
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] # NotifyMovingToTargetEnded Fraes1_100
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] NotifySimulationEvent MotionToLocation Fraes1_100: OFF (3,26591992378234ms)
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] # SetVariable MyDelay 8 / 3
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] # WaitTime MyDelay
ir_110010r02[RRS]> Interner Fehler an (Wz1_Fraesen_Flanke) Fraes1_100: SimulateWaitTimeStep2 - wrong parameter type
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] # NotifyProcessingTargetEnded Fraes1_100
Still any ideas? Smiley Wink
Okay, there are still problems:
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] OnLocationReached: 5,78188786506654
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] NotifySimulationEvent MotionToLocation Fraes1_100: OFF (5,78188786506654ms)
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] Notify ProcessingTargetEnded Fraes1_100
<SimulationLayer>
   <If>
      <Line>
      </Line>
      <Line>
      </Line>
   </If>
</SimulationLayer>
Any further ideas? Smiley Wink
unfortunately not. Smiley Sad
<SimulationLayer>
   <If>
      <Line>
      </Line>
      <Line>
      </Line>
   </If>
</SimulationLayer>
Any further ideas?
Unfortunately not. :/
Now the code looks like this:
<SimulationLayer>
   <If>
      <Line>
      </Line>
      <Line>
      </Line>
   </If>
</SimulationLayer>
When I try to run the function, the trace throws an error:
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] OnLocationReached: 7,03987183570865
ir_110010r02[RRS]> Hinweis an (Wz1_Fraesen_Flanke) Fraes1_100: [DBG] NotifySimulationEvent MotionToLocation Fraes1_100: OFF (7,03987183570865ms)
Any further idea? Smiley Happy
[Code]
<SimulationLayer>
<If>
<Line>
</Line>
<Line>
</Line>
</If>
</SimulationLayer>
[/Code]
[Code]
[/Code]
please check these thinks.
1.check function without "IF" condition
2. test function without Custom XML. Write the logic directly in OLP Commands
3. delete the empty letters <Item Type="const">/ 3</Item>
4. what is the data format from "MyDelay" ? INT?
Kind regards,
Benjamin Voelzke
1. Done - no difference.
2. pending. Smiley Wink
3. Done - no difference.
4. Input is INT, but MyDelay could be float. (F.E. 10/3)
Why are you asking? Is it necessary to declare the variable?
i can reproduce your wish.
PS convert the # SetVariable MyDelay 8 / 3 to string not to INT.
Sorry in these case i have no idea.
Kind regards,
Benjamin Voelzke
