Cannot update EMS after creating swept volumes
Hi
I am working in PS13.0 and after I create a swept volumn I get the below error when I try save. I have checked that there is a Volumes directory as I thought this could be the problem. Thanks
Error
Save to eMServer
eMServer update failed due to failure in writing the XML to export to the eMServer. Contact the eMServer system administrator for assistance.
OK
Re: Cannot update EMS after creating swept volumes
I don't believe it's related to the swept-volume-function itself.
Maybe some process or access right blocks your TuneCell-folder. (the one, named by the ID of your study)
Did your PS crash before this happend? Any running tune.exe-tasks besides your active PS?
You may use the program "Unlocker" (google it) to check if there are files in that folder are bound by a process.
If it doesn't help, don't hesitate to contact GTAC.
