Cell converstion to Catia
Hi, using the command cat5_t out in a .bat file I can convert a .co to a CGR However I noticed in the help notes it says it can convert a cell as well, but when I try it will do some axis (of what I have no idea) but cmd window says it can't find various components in cell.....
Has anyone managed to convert a whole cell?
Thanks in advance.
Re: Cell converstion to Catia
I cannot give you a testet solution, as I have no Robcad anymore.
But it tells me that you might have to set your library root.
If you work on cmd, you'll have to set the lib-root as environemt variable.
If I remember correctly it's LIB_ROOT
