Change default via naming
Hello guys,
Is there any way to change the default naming convention of via locations in PS?
In the manual it writes: "By default, all via points are named via#"
Re: Change default via naming
Siemens Legend Siemens Legend
Siemens Legend
Hi Endre,
no, that cannot be customized currently.
you can use the rename fuction to change the names after creation.
Best regards
Bernard
